Allis Chalmers CA transmission oil
MartyD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MartyD Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers CA transmission oil
    Posted: 08 Nov 2011 at 5:38pm
I need to know what to use in an Alllis Chalmers CA tractor for transmission oil. If it
should be a non-detergent 20 w oil or is there something else I can use? Any help would
be appreciated.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2011 at 6:48pm
First welcome to the best web site.
Yes 20 weight non-detergent because the hydraulic pump gets it's oil from there.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2011 at 9:37pm
20W non detergent motor oil was what they originally used. You can use universal tractor hydraulic fluid in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2011 at 10:27pm
Go to the local farm store, auto store, or wal mart.. Look for universal tractor fluid, hytrans, or hydraulic- transmission fluid... any will work great.   - buy a 2.5 gallon jug- use almost all of it.
Edited by steve(ill) - 08 Nov 2011 at 10:27pm
kenbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenbob Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2017 at 7:52am
My pump is leaking quite a bit. Is 20 wt oil thicker than hydraulic fluid and a better choice  since I have leaks?
tadams(OH) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2017 at 2:15pm
Yes, 20W is thicker, heavier
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2017 at 9:11pm
Heavier oil will make very very little difference in amount of oil it will leak when it gets hot. Use the newer oil, universal hydraulic.    MACK
