moving LM corn head spacing- how hard?
clint View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Topic: moving LM corn head spacing- how hard?
    Posted: 26 Oct 2011 at 9:41am
want to move my head from 38 to 36 this winter- how big a deal is this- looks like i would need a couple cogs- anybody done this before?
Our farms stuff: agco gt55, AA 8775, 8765, 6080, 185, 180, 175, 170, d15, d14, d14, wd, wd, wd, g, F3, L3, R62
BRYAN H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BRYAN H Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2011 at 9:55am
WILL TAKE SOME TIME. HAVE TO CHANGE SHAFTS BETWEEN THE UNITS. YOU HAVE 4 INCH. THEY NEED TO BE 2 INCH. ALSO NEED TO SLIDE ALL THE TIN WORK IN. YOU CAN MAKE SHATFS FROM YOUR OLD ONES. HAVE FUN
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2011 at 10:02am
thanks bryan- hadnt thought about that- just cut out the middles and re-weld- if things go well i might not need any parts (yeah, right!)
Post Options Post Options   Thanks (0) Thanks(0)   Quote BRYAN H Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2011 at 10:20am
I WOULD WELD THE SPROCKETS BACK ON THE SHAFT. YOU CAN GRIND THE WELD OFF. THE ONLY THING YOU MAY NEED IS SOME BOLTS. AFTER TWISTING THEM OFF.
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 10:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 10:01am
took 3 hours with a help to move the units- the tin work should take all that long i hope.
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 10:09am
forgot to mention- had a rain and will rain the next couple days so got a wild hair to do it. if i can finish in anothe 6 man hours i think it might pay the labor bill with the saved ears with the amout i have left to do- i should have done this sooner. going to replace the roller chain on the units while in there- they dont look bad at first glance- but got one off and the insides are not so hot- with that chain you cant see the wear that easy. i am glad i did this so far.
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 3:26pm
The year I worked for Remington Hybrid Seeds I learned that as soon as they had all the beans run through their bean combines(2) they put them in the shop and gutted them. Every bearing and bushing was checked for wear,along with other parts. If something looked at all questionable it was replaced with new. Sounds expensive,and from my point of view they repalced a lot of good parts. But, with the 7-8000 acres of seed beans that were ran through these two machines,with NO downtime,it was very cost effective. I thought they were only 1 maybe 2 years old and was shocked when I was told one was 8,the other was 9 years old! They were washed and detailed as soon as repairs were finished, they were blown clean with air at every change of seed variety,inside and out! Little nicks and scratches were repainted,just like UPS trucks are when they come in for service. It truly was amazing! With 30' heads it was common for them to do 200-250 acres per day every day it didn't rain! Their seed corn pickers were handled the very same way!
This page was generated in 0.262 seconds.
