wd 45 oil filter question?
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Topic: wd 45 oil filter question?
    Posted: 09 Oct 2011 at 9:23pm
I know it has been talked about before how oil filters  affect oil pressure on a 45, refresh my memory on which one are good and which are not.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 9:27pm
The Fram C-159 and the NAPA 7011/ Baldwin 57011{Same Filter} are OK.
The old NAPA/Baldwin that are no longer available were not so good.
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 9:30pm
AGCO ones are OK also.
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2011 at 7:20am
I thought the baldwin T-300 was a good one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2011 at 7:30am
The oil filter needs to be packed with cotton not a pleated paper filter. All the bad, pleated paper filters had a rubber insert in the center of the filter and you could see the pleated paper inside.
