d17 no start
bradley69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley69 Quote  Post ReplyReply Direct Link To This Post Topic: d17 no start
    Posted: 09 Oct 2011 at 6:09pm
if ant one thing its some thing else. now the tractor stop running it took me most of the day to get the air out from a guy that show up to look at the tractor with out me here the wife seen him at the tractor then was gone left the fuel bowl of and $70 of fuel ran out. got the tractor running and moving around and the it stop like it was out of fuel i put more in has 1/2 tank of fuel i have fuel to the injectors starts on starter fluid and dies
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 7:50pm
I had a real problem getting my 45 diesel primed the first time.  I ended up cheating and cracking the lines and wrapped a towel around a air nozzle and put small shots of air into the tank to "pressurize the system".   got the air all worked out and to the pump and then it still took alot of cranking to get it all bled out.   I would crack all the lines at  the injectors and crank it till it starts leaking by the injectors and then tighten them up.   I remember it took a good part of the day doing this with giving the battery some charging time and the starter some resting time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley69 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2011 at 5:25am
i had it running for 30mn then it stop like the fuel ran out but there fuel to the injectors. how can i tell if the injector pump working
This page was generated in 0.126 seconds.
