wd distributor
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Topic: wd distributor
    Posted: 06 Oct 2011 at 9:17pm
Will a distributor drive from a FarmAll Super C fit a WD? It is a straight through design, no angle. I have seen a picture od a WD with one on, but wanted to check with those more knowledgeable, thanks, Trev.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2011 at 2:18pm
Anyone??? Someone???  Trev.
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2011 at 5:36pm
 YUUUPPP          Slot  is  same  as  mag,  repaint  and  go,  be sure you can get internal parts  if  it  is  IHC  &  Not  delco.     Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2011 at 11:14pm
Thanks Tony, its a delco unit, Trev.
This page was generated in 0.077 seconds.
