Allis B
barky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote barky Quote  Post ReplyReply Direct Link To This Post Topic: Allis B
    Posted: 03 Oct 2011 at 2:42pm
I'm restoring a Allis B anyone have a wireing diagrama?Does the harness go under the battery box? Thanks
1953CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2011 at 2:56pm
Yes, just did a 12v conversion on mine, and I put the wiring harness under the battery box through the angle bracket in the tool box, and put the distributor wiring to the right of the gas tank instead of around the front of the engine and then back to the ignition coil, cleaner look...
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support"
