help id this mag please.
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Topic: help id this mag please.
    Posted: 26 Sep 2011 at 6:46am
it says fairbanks morse type fm 4b. 265719
30 degree impulse angle. this is what I was using on my 35 wc. need parts. thanks
waynem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote waynem Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2011 at 7:00am
That is the same magneto on my 39 Model B. My serial # is 298166
1939 Model B
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2011 at 7:10am
Glockhead SWMI, That's a Fairbanks-Morse FM4B.
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2011 at 7:46am
If you are looking for parts it would be an FMK 4B and there would be a 3 after that number if it was originally shipped to Allis Chalmers, so FMK4B3.
Parts are not readily available for that mag like they are for the FMJ or FMX.  Some of the rebuilders still have some parts for it though.  I was able to get some NOS parts for mine on eBay.  I think the coil number for the K is U2477C, the coil for the FMJ can be used in it you just need to center it and tighten it down and then add a couple inches to the wire to make it reach.  The rotor is an odd thing too and gets a pit worn in it where the spark happens, it just eats a deep divot into it.  If it isn't too deep you can use a surface grinder on it and take the whole face down to where it is smooth and level.
Here is a link to when I was rebuilding mine:
http://home.comcast.net/~old_allis/ac-RC-magneto.html
You may want to check with Steve at B&B, I got some parts for mine from him.
Edited by TomMN - 26 Sep 2011 at 7:50am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2011 at 7:54am
If you want that magneto rebuilt with new parts, remagnetized and painted give Belanger's Auto Electric {Mainely Magnetos} a call.
I had them do several of those and when they come back they are like new and work perfect.
207-834-7309
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2011 at 9:01am
I wonder if this is worth trying to repair or if I should look for another mag.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2011 at 9:07am
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2011 at 9:12am
I have that same mag on a 39 RC, must have been popular that year.
arrowcreekfarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote arrowcreekfarms Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2011 at 9:29am
Rebuild it! Mags are expensive and unless you see it work you wont know if it does work. I bought a mag for an off color tractor to replace the bad mag I had, it had spark but a bent shaft done me in and I wouldve been better off rebuilding my mag and the ease of mind knowing it was rebuilt right with a backed warranty and all new guts!
1972 200 diesel, 1966 190 Gas, 1962 D-15 Gas w/ #15 loader, SC 3-16" Plow, SC 8ft disc, SC 2 Row Cultivators, 500 Series 4 row Planter
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2011 at 9:40am
If I can find parts I'll fix it up. looking for a cap and rotors now. found everything else. this mag has spark but it is very weak. hope to fix it and my wc might start easier. thanks
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2011 at 12:54pm
I'll bet all the parts to fix it up are available new. I bought just about everything needed for a full rebuild of a FMJ and it cost just about 150.00. That didn't include the cap since I think mines OK. They are about 65.00 by themselves.
Greg (Hillsboro, OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg (Hillsboro, OH) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2011 at 1:09pm
Steve at B&B will have everything you need to fix it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2011 at 1:20pm
I have found most of the items. No cap or rotor yet. The seals,gaskets and bearings seem good. Curious if the magnets were weak if that would cause a problem. do the magnets fail over time?
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2011 at 7:29pm
 WE HAVE FM MAG PARTS  1-800-254-3116
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2011 at 10:59pm
Recharging the magnets is something a good magneto shop can do.
Gerald J.
