crankshaft torque pattern on wd
acdad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acdad Quote  Post ReplyReply Direct Link To This Post Topic: crankshaft torque pattern on wd
    Posted: 24 Aug 2011 at 9:17pm
new to working on ac tractors all i have for a manual is an I&T. It doesn't tell me what the crankshaft main bolt torque pattern is on my wd it tells me to torque them to 85 ft. ibs but that is all thank you for any help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2011 at 9:36pm
There are only 2 bolts on a main bearing. Go back and forth between them tightening each one a little at a time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2011 at 9:39pm
The main thing on tightening these up is making sure you have the proper amount of shim in place or you will over crush the bearings and things won't turn like they should.
Post Options Post Options   Thanks (0) Thanks(0)   Quote acdad Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2011 at 10:00pm
thank's for the info
This page was generated in 0.193 seconds.
