8050-8070 hyd flow
riggs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote riggs Quote  Post ReplyReply Direct Link To This Post Topic: 8050-8070 hyd flow
    Posted: 20 Aug 2011 at 6:13pm
Does anybody know how many gpm the hydraulic pump on a 8050 and a 8070 are?  Buying a vac planter and was wondering if that would run it?  Thanks in advance  Mark
Dean/MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean/MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2011 at 7:05pm
We just set up a 16 row White on our 8030 this year and used a pto pump. It only has 2 hyd spools and we either needed to add one or use the pto pump. With the extra pump you don't need to worry about flow.
Edited by Dean/MN - 20 Aug 2011 at 7:15pm
HD16,917H,185,7050,8030FWA,8050FWA
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2011 at 8:17pm
      Very nice setup !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean/MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2011 at 8:28pm
Our corn seems to have more uniform population than the guys with the new green planters.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2011 at 9:12pm
8050 is 23 gpm and 8070 is 24 gpm if the pump is in good condition.
