WD-45 Shifter ?'s
1953CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 Shifter ?'s
    Posted: 15 Aug 2011 at 9:24am
I picked up a 1955 WD-45, and I was told the shifter falls out of gear.  It currently is out of the tractor, can some one build this up for me or have a good one for sale?
Andrew
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support"
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2011 at 9:37am
They are easy to build up. Either weld or braze the end that looks kinda like a ball on the sides. Then file or grind both sides down to about 5/16ths of an inch,( I use a 5/16 wrench for a measure). This should be enough to help. You might have to go to 3/8 inch, but usually I don't
