5020 issues
Charlie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie Quote  Post ReplyReply Direct Link To This Post Topic: 5020 issues
    Posted: 15 Aug 2011 at 8:02am
I have a 5020 and is a great tractor but there is an issue with it wanting to over heat. I try and keep the radiator clean but still over heats if pushed. Previous owner took out the thermostat and I'm wondering if that's making it worse.
It also gets a dark oily film on the battery terminals and I have to keep cleaning them so it will start.
Any ideas to fix these problems?
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2011 at 1:18pm
I just had the battery problem.  Was caused by the ground cable, loose connection.
The overheating may be caused by the rad being plugged.  I had mine off when I changed the water pump, and it took me about two hours to get it washed out!  Runs lots cooler now.
nsula_country View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsula_country Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2011 at 2:52pm
Sounds like you need to take your radiator to a good shop and have it rodded out. My Komatsu excavator was doing that last year. Cost $60 to have them boil it out and rod. Cheaper than scorching an engine.
CT
