Snap coupler lift arm latch springs
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Topic: Snap coupler lift arm latch springs
    Posted: 08 Aug 2011 at 8:49pm
I'm in need of a set of replacement lift arm latch springs.  Does AGCO handle these?  Does anyone know their price?  Any assistance would be greatly appreciated.  Thanks!
daveingreenbay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daveingreenbay Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2011 at 9:04pm
Check with Tracy Martin, he should have everything you need.  excellent quality, at a fair price
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2011 at 9:23pm
Actually I am out of the springs at present. Roger Van Camp will have the correct springs. Some vendors offer a spring ,but they are not correct. The originals had a double coil loop on each end. It keeps it from coming off. Make sure to get the correct ones, you won't be happy with the others. HTH Tracy Martin
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2011 at 9:26pm
Almost any hardware store that sells springs can have them ordered. I got mine from ACE
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2011 at 9:41pm
Doc Smith has them
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2011 at 9:43pm
Doc is a great guy too. Tracy Martin
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2011 at 9:16am
How do you remove the twist rivet which holds the spring? One of the ones which holds the spring is broken.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2011 at 9:29am
Got mine at ACE also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2011 at 10:09am
Clay, it is called a drive screw. It is hard also, heat it with a torch until red, let it cool ,it should soften up enough to carefully drill it out. Really helps if you have a vertical milling machine. HTH Tracy Martin
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2011 at 10:19am
Tracy,
How easy should the couplers be to open and close? I bought a used set and they are tough. How do ya get them to loosen up? Was thinking about just soaking them in degreaser for a while.
1954 WD45 NF "Iron Tater"
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2011 at 8:56pm
     A degreaser removes "grease", it is not a lubricant !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2011 at 9:10pm
Jeff, they should not bind on hinge rivet. They over center on the spring. New springs make them real stiff to open. Spray some Kroil on and into them. That should help things if hinge rivet isn't bent. HTH Tracy Martin
