82T sickle mower
Walt(E-IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walt(E-IA) Quote  Post ReplyReply Direct Link To This Post Topic: 82T sickle mower
    Posted: 04 Aug 2011 at 9:32pm
I was out cutting a little hay with my AC 82T mower yesterday when the knifehead broke. On closer examination, it appeared that the knifehead was rather loose fitting in the bushing. If I get a new knifehead, is it going to fit tight, or is there some way to tighten it up? I've ordered a manual for this mower, but haven't gotten it yet, so I was hoping someone here could help. Thanks.
Walt
Flint23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flint23 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2011 at 1:26pm
the bushing should fit in tight,but moveable with a slight tap of a hammer.check for loose nuts under the crossbar, that's what caused mine to break.
been there done that, not doing it again...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walt(E-IA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2011 at 9:19pm
I think my problem is a worn bushing. There is a bolt that holds the knifehead, but it is as tight as I can get it and there is still a lot of play between the knifehead and the bushing. I'm thinking the bushing may be worn too much or the knifehead end is worn, or both. Anybody have a spare bushing?
Walt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flint23 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2011 at 5:59am
Have you tried to tighten the crossbar capsrew? Maybe this pic. will help.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2011 at 9:33am
Last time I checked at the dealer (about 5 years ago) they wanted $106 for one!
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walt(E-IA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2011 at 9:54am
Flint23 -- Yes, I have tried tightening the crossbar capscrew but it won't tighten enough to take the slope out between the crossbar and the bushing. I'll take it off the mower later to see if there is something in there preventing it from going tighter.
Eldon -- $106...Ouch!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flint23 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2011 at 8:06pm
while you're at it check your connecting rods for slop ,might have a bad bearing, they should be tight also.
This page was generated in 0.101 seconds.
