200 Pulling
HARVESTMOONPULLER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HARVESTMOONPULLER Quote  Post ReplyReply Direct Link To This Post Topic: 200 Pulling
    Posted: 02 Aug 2011 at 10:58pm
Building a 200 for pulling this winter. Taking a plunge into deep waters from antiques.
Basic rules 510 ci 3"by3.5 charger Ppump 18.4x38s single water injection stock appearing manifolds.
Ill be running the faithful 301 so im gonna need some help trying not to spend too much money starting out. Anybody got any suggestions? Im also looking to drop alot of weight this winter(me and tractor)LOL Any help would or advice would be greatly appreciated
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 3:12am
 ;  Your gonna need 2 turbos on a 301 to make it any thing close to competitive  ; then with that big of gap in the cubic inch ; 510 to 301, you may see about putting a 426 in it , some clubs will let you ;  Its gonna cost a bunch of $$$$$ ; and you still will be behind ; a P pump and turbo,s around ten grand for good stuff !!
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 5:37am
I know where there is a 426 that is affordable, complete, and just what you need to get the "base" powerplant you need. It may even have a german crank in it as a bonus. Seller was told it is ready to run [ by previous seller], he has no way to verify this [ does not want to spend time either]. It is located in NY.
DarrylinWA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 6:04am
Go to this web sight  www.thefewtheproudtheorange.com.  or go to www.pulloff.com  Sometimes you can find a turn key set up on there for cheaper than you can build.
Best of luck!
Take care, Darryl
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 6:54am
NO WAY....you cannot expect to run a 301 against a 510.
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 8:32am
I wouldnt say ...no way... but its going to be an extreme up hill battle at the least. I have built 301 into pullers in a farm cheater class (unofficail name) and we competed with 466 JD and 466 IH engines shoe horned into smaller tractors like 766 or 4020, and we could walk them with out alot of problems, however just so you are aware when a 301 walks a 466 JD or IH be prepared for a fight because IH and JD guys do not take getting beat very kindly!!!!!!!!!!. My opinion of putting a 426 in would be a better idea, but than again a IH or JD guy putting a 466 in a 4010-20 or a DT 466 in 766 etc seems exceptable but when there is a hint that a 301 has been swapped with a 426 these guys cry FOWL. Been there done that, Allis Chalmers is not a welcome sight in the pulling world. Which personally makes it more fun .
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 8:47am
I found the same thing when my D17 was ruling the farm stock 6,500# and 7,500# classes and trophied often in the classic non stock classes. That really bothered them that my old rusty stock 17 could beat their shiny hopped up Deeres. Your friends disappear quickly in the pulling world. Even had to dyno my tractor special to prove it was stock. I never bragged about my tractor to any of these guys but put up with a lot of put downs. There were a few good guys who didn't mind my 17 doing well but most turned a cold shoulder. That's the biggest reason I left the pulling world after about 7 or 8 years.
Wink
I am a Russian Bot
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 10:00am
X2
You might as well try holding the tide back with a broom.
Mark
GTH-L Simplicity
Mark D. View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark D. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 11:27am
I agree with Dr. Allis.  It took us two turbos to compete with 407ci limit here.  My advice...   Get yourself a 210 or 220 out of a boneyard and go from there.
Miss Behavin - D21 Super Farm
Xcessive Tinkering - 190 XT Hot Farm Puller
Watch on YouTube - http://www.youtube.com/watch?v=J2TX1Af7aoA
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 3:25pm
X4  I agree, there's no way for a 301 with 1 charger to compete with 510's! Even if you have endless supply of money!
Post Options Post Options   Thanks (0) Thanks(0)   Quote HARVESTMOONPULLER Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 4:09pm
Ok let's look past the 510 limit kuz there's several 301s pulling in it and last I saw were very competitive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 5:11pm
Old school thinking says it cant be done, the old no replacement for displacement theory, which from a money stand point does hold some water, but today cu in can be replaced unfortunatly its replaced with money, and lots of it. 466,DT's ford 401-476 can be beat by a 301 but its not easy, and as every puller should know it takes more than power to get to the end, its a combination of things, tire size,brand ,inflation, balance ,hitch   point,driver skills  track, etc etc etc. A few years back a guy asked if his 210 could out pull a 6030 everyone  that responded said there was no way, except in reality he beat it. Nothing is impossible but its an uphill battle. When the 301 I  built was out running there were  4 301's 2-185 1-180 and a 200 they were all pretty close to the one I built one had a inline pump, one had a ambac, and 2 rosa's they all pulled the best in the 7500# area give or take 500 # and the funny thing is if they all showed up for the same pull, the AC's would be 1-2-3 the order would change some times but they would always hold the top spots.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 7:45pm
A 200 is a good choice for pulling  ;  you are gonna put alot of power into 18.4-38 inch rubber ; to bad you cant run 24.5-32,s !!!! You will have to gear it straight thru , but that aint no big deal ; go to MSTPA .com ; Jere Setter advertises on there , they run the Orange Crush tractor and run very well ; he works on alot of 301,s and can help a bunch , he,s a super nice guy and will steer you right ;  AC,S LUV MULTIPLE CHARGERS - MORE AIR -  thats the only way you may keep up
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 7:46pm
Yes,lot's and lots of money! Wouldn't take as many dollars using a 426. And all of us AC lovers, love it when they beat the red and green ones. But Oranges ones need a much bigger pocket book to be competitive! Or some sponsors to help with one. :)
Good luck with it! and keep us posted on your progress.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark D. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 7:52pm
Do what you wish.  As soon as the 510's spend the same money you did on the 301, those 200 cubic inches are gonna put you behind 25ft on the track.  This is coming from a guy who has pulled his whole life as the underdog.  Sorry!
Post Options Post Options   Thanks (0) Thanks(0)   Quote HARVESTMOONPULLER Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 10:58pm
suppose i did go with the 426 what am i gonna have to worry about as far as the rear end, clutch, and power director?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2011 at 6:16am
Steel flywheel with at least a double disc clutcxh.....Power Director has to go and replace with a coupler......needle the differential.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HARVESTMOONPULLER Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2011 at 6:21am
Whats the coupler from can i find one or do i have to buy one? Will i be able to use high or low and just not be able to shift or will i only have high gears or low gears?
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2011 at 6:46am
Replace the PD with a coupler and you will have HI range only, which is actually direct drive. Low range is actually an underdrive in each gear......
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2011 at 9:25am
Just to be straight here, it takes more money to make an Allis competitve, not because its  an allis its because the JD & IH guys have riverside and hypermax spending bu-ku bucks making red and green run. The last real AC man(Noble Harris) that had the time money and company backing for AC has been dead for years, and everyone else in the AC pulling field has to start from scratch to get the job done. There isnt very many off the shelf, or out of date pulling technology to buy for an Allis Chalmers, which ups the cost substainally . Max SImpson has some of the answers but most of the problems have to be trial and error and one off parts that ups the price and time it takes to make an AC pull. However as much as the main stream pullers hate to see an Allis Chalmers, deep down they all know its lightning in a can, just waiting for the right combination to be let out, and the crowds specailly the older gents just love the site of a an Allis Chalmers out on the track dominating again. Make no mistake though its an up hill battle, but  it is fun when you get it right, but never finacially.
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2011 at 12:11pm
What is the max cube you can get out of the 301 and 426?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2011 at 6:59pm
I am not sure on the 301 but 426 can be bored to 531 and you could stroke some more into that
kffischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kffischer Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2011 at 8:40pm
Part of me says a 200 is rare enough not to mess with it.  The rare sheet metal parts and the mechanical goodies early 190 owners wish for should be considered in choosing the actual tractor/pieces used to make your puller.   You can make a pile of preferred for pulling parts into a "200" with decals and paint too--only the allis fans will know what's different :)
karl f
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2011 at 11:00pm
Back in the 70's and 80's there was a guy from our area here who ran a 180 diesel for pulling.  That thing was very competitive and at the state pulls he would beat 210's and D-21's all the time with the 180.  I wouldn't say your idea can't be done, it just takes the time, the know-how, and of course the money.  Good luck in your venture.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2011 at 6:21am
If you get a 180-190-200 to consistently beat up D21's, IH1066's, etc......they aren't trying very hard. Cubic inches make "X" ammount of HP and when you have way less cubes than they do you will always be behind.
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2011 at 12:42pm
You can get well north of 650 out of a 426.......
Making a living farming with and working on Allis Equipment
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark D. Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 9:40am
650 plus...   Really?  Who's rules would that even fit into?  Heard of only a handful of motors build to 640 to pull superfarm and only a couple lasted over a year.
This page was generated in 0.124 seconds.
