D17 power steering weight
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: D17 power steering weight
    Posted: 20 Jul 2011 at 7:25am
I am removing the narrow front pedestal and power steering group and wondered how much it weighs. I don't want to be surprised when I take out the 4 bolts and have it weigh 200 lbs.
Also I assume once I take out the retaining bolts that the entire unit will slide forward? I do need to remove the steering coupler and the pulley pump lines first but otherwise it looks like it will just slide out as one unit.
Thanks
Charlie
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2011 at 7:28am
It took two to lift the one for my D14.  I used a cherry picker to install it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2011 at 7:53am
Steering coupler slides apart. If you've got the front wheels still on it, I'd guess 350 lbs anyway for the whole enchalada.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2011 at 8:19am
I took off the wheels and will remove the lower pedestal so I can check the bearings. So I guess I will need to use the loader to help remove it unless I can convince my teenage so to lend a hand.
Thanks for the help
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 12:01pm
Holy cow, Motion Industries wanted $235.00 for the Bearing Cup! Said it was a special sized item
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 3:37pm
Call Sandy Lake. No where near that price through them. Probably closer to $23 through them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 4:49pm
Yeah I got it from Sandy Lake, $68 for bearing and cup
Charlie
