Why single front wheel?
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: Why single front wheel?
    Posted: 05 Jul 2011 at 2:43pm
Guys-Wondering why some of the tricycle tractors had a single front wheel.  What was the original purpose of this design?
Thanks in advance
Terry
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
Goose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2011 at 2:46pm
Uh oh! There you gone and dun it! You asked the age-old question about single front wheels. That'll open a can of worms, I tell ya!
I think it has to do with Eistein's Theory of Relativity.
You see, you get your relatives to lay on the ground whilst you run over them with the single front wheel!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2011 at 3:08pm
Sorry, I couldn't resist.
To make it easier to cultivate vegetables and beets and things in narrow rows.
Narrow rows....
But don't forget about crops grown on raised beds - the area between the beds isn't wide enough to fit 2 tires in (like a conventional narrow front), and if you use a single tire, the tractor will more or less 'steer itself'.....
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2011 at 3:20pm
So you only had to fill one front tire when it went flat instead of two
"Better By Design"
ky wonder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2011 at 3:23pm
here in ky they where used for cultivating tobacco, the single wheel would let you get another pass at cultivating the crop without damaging the growing leaves, which is the part you sell.
a lot of farmers would remove one side of a regular two wheel tricycle front to get the same option
i like old tractors of all colors
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2011 at 4:47pm
they also said the single front wheel worked better with a mounted corn picker   was not supposed to ball up in southern IOWA gumbo soil
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2011 at 6:18pm
all the things listed above...also, alot of farmers used to pack their just planted rows of seed, to expedite the seed to start growing, and the single front wheel did better than the 2 front wheels. so...each pass would pack 3 rows. had to plant pretty even as planters planted in groups of 2's...2-row, 4-row, 6 row...on up, and packing was done as 3-rows, 5-rows and such...some did make a 4th row packer wheel mounted on the back, using a truck wheel.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2011 at 6:42pm
That's what my Dad thought one muddy fall (M Farmall and a 2M picker) it was as bad or worse until he put a smaller tire on it.  In normal conditions, it made following the row easier as cultivating would leave a furrow in the middle.
Mark
GTH-L Simplicity
JeffHillNC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeffHillNC Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2011 at 8:00pm
Back years ago when I was young my uncle bought a wd45D from another ac farmer for the front wheel, the engine was frozen and split so we pulled the front pedastal and wheel to put on a wd we used alot. The biggest difference we saw was putting out nitrogen to corn. At fast speed the single wheel didnt kick and buck the steering wheel as bad and in moderate soil actually would track by itself alot of the time.
Qualityusedmowerparts.com
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2011 at 8:22pm
Back when white navy beans were grown in this area, the single front was often used on the tractor used on the bean puller.
Dusty
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2011 at 8:53pm
      The only bad thing that I can tell you about the tricycle front wheel is : Do not forget to use the right and left brake pedals while cultivating near the outhouse !!! Believe me, you will not turn, as the top soil is pretty  loose after doing the end rows first. Took out a fairly good chunk of it  !!! I do hear about it to this day !!!
junkman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2011 at 10:26pm
Auntwayne your experience makes me wonder who still has a outhouse? I almost hit mine with the d17 the other day.
Ed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2011 at 6:52am
All D Series one row cotton pickers had the single wheel...worked great with
a 4-row cultivator!
Ed
trikesbikes@gmail.co View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote trikesbikes@gmail.co Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2023 at 12:48pm
What is the weight difference between a single wheel front and the weight of the narrow front WD 45 and or The single wheel front and a wide front WD 45 thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote trikesbikes@gmail.co Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2023 at 12:49pm
Also is any for sale single wheel front for WD 45 thanks
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2023 at 7:59am
Well, I assume they are somewhat lighter than a tricycle front, maybe someone here knows the weights? They do come up for sale once in awhile, always seem to bring pretty good coin.
Post Options Post Options   Thanks (0) Thanks(0)   Quote trikesbikes@gmail.co Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2023 at 8:26am
Had a couple response but I didn't know that it's cast iron so not saving any weight thanks for the response!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2023 at 8:53am
About as "light" as you can get and still look "stock" is use a narrow front end assembly from a WC as they are quite hollow inside and weigh 90 lbs or so LESS than a WD45 narrow front.
Post Options Post Options   Thanks (0) Thanks(0)   Quote trikesbikes@gmail.co Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2023 at 9:05am
Any pacific year? Thanks for all the Post you put on hear save Alot of Head aches and pocket books!
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2023 at 7:23pm
I have no experience with the WD / WD45 single front wheel, but I have a CA with a factory single front wheel. The single wheel is VERY heavy. Unless the WD is different, I'm betting the single front wheel isn't much lighter than the narrow front, unless you can replace the wheel with something much lighter.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2023 at 9:26pm
i had the single front wheel off a massey harris 44 about a month ago to do wheel brgs. and paint and i could barly lift the tire and wheel/     i would almost bet its heavyer than the narrow front with tires and wheel ,    the yoke that the wheel goes on was made out of real heavy sized steel
Post Options Post Options   Thanks (0) Thanks(0)   Quote trikesbikes@gmail.co Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2023 at 10:32pm
Thanks for the info!
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2023 at 11:46pm
I've a D15 1 with SFW has 9.50x10 tire, manual steering, 13.6x28" rears. Its Wheel assy is heavy and the cast fork  that holds wheel & tire makes it heavier than a std NF end. The steering gear leaked when I got it so took it apart. The tire size is hard to find. It's hard to steer in soft soil, the D17 I w/ NF & man'l str is far easier to steer.
 I've papers from when it was sold new, equipped as it is, I'm second owner.
