G locked up need help
Gourdo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gourdo Quote  Post ReplyReply Direct Link To This Post Topic: G locked up need help
    Posted: 25 Jun 2011 at 10:36am
I have a 1949 model g that was working fine, then I thought the starter was going bad, and I had to pop start it a couple times and she fired right up.  Now it won't pop or turn over with the hand crank. Any suggestions would be much appreciated.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 4:51pm
IF the starter is not removed it may be wise to remove it.  It may be locked up there.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 6:41pm
Remove the starter like Bill says. Probably need the starter gone through.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gourdo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 7:40pm
Good call, there was a mouse nest in there jamming up the starter teeth, cleaned it out and she turned right over, didn't start but should be easier from here. Thank you Bill
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 8:00pm
Gourdo, glad it was more serious, and things are back working. When I got my G last year, it wouldn't turn over with a new battery. I took the starter out and removed a 5 gal bucket full of mouse nest. It still wouldn't turn over since mouse pee froze the starter up. After a bunch of dis-assembly and cleaning I found a bad connection in the starter and had it repaired with a new "button" for the starter switch.
