Char-Lynn Hydraulic Unit
BWild View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BWild Quote  Post ReplyReply Direct Link To This Post Topic: Char-Lynn Hydraulic Unit
    Posted: 23 Jun 2011 at 10:08pm
Need a coupling disk for an AC B tractor mount.  Any ideas as to a source for one or the material to cut and drill one myself?
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 8:38pm
   Go to your farm supply [tractor supply or such] look at weld a sprocket display get 2 hubs one for your P T O shaft & one for the pump get 2 sprockets same size & a peice of # 50 dbl roller chain a half link & a coupling link.    no more problems stays to gether- stays lined up when you take the pump off   did mine years ago. It sounds like you have a henderson loader those old alum. couplings where junk .
