PTO GEAR BOX WD45
beaglejoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote beaglejoe Quote  Post ReplyReply Direct Link To This Post Topic: PTO GEAR BOX WD45
    Posted: 20 Jun 2011 at 2:44pm
How hard is it to replace the housing where the PTO Gear Box attaches to? It looks like 4 bolts on each side and it should drop out. I have a chance to buy a WD45 that has a hole in the housing right above the PTO gear box. This is the section where the PTO Gear Box attaches to. The owner claims it got hit hard by a log when he was brush hogging.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2011 at 3:23pm
I'm thinking you are talking about the transmission housing. You'll have to remove the transmission. If there is a hole in the side of it, you will more than likely need some new internal parts. Might be best to have a donor tranny to swap out so you don't have to take all the shafts and gears out.
231. R & R TRANSMISSION. Drain
oil from torque tube, transmission
and differential housing. Support tractor
under torque tube and rear portion
of main frame and transmission.
Remove rear wheels and final drive
assemblies as outlined in FINAL
DRIVE section, and differential and
bevel ring gear unit as outlined in
DIFFERENTIAL s e c t i o n . Remove
drawbar, battery, battery carrier and
power take-off shaft. Remove steering
column to transmission housing retaining
cap screws. Disconnect brake
pedal rods and engage transmission
clutch. Remove rear platform and
power lift arms and shaft. Remove
main frame to transmission retaining
screws. Remove nuts retaining transmission
to torque tube. Roll transmission
housing away from torque tube
Gary in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2011 at 6:18pm
The PTO is attched to the torque tube, not transmission.
Do the same steps above  and then unbolt the torque tube from the clutch housing and make the change.  Not a lot of internal stuff to mess with like in the transmission.
Edited by Gary in Texas - 20 Jun 2011 at 6:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote beaglejoe Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2011 at 6:37pm
Thanks, wasnt sure what that section was called as it is the section the PTO gear box attaches to. So when you remove the torque tube, you dont have to mess with any of the transmission. SHould it drop right out.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2011 at 6:38pm
I have that housing ready to ship, PM with your zip and I can get you a quote.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2011 at 6:41pm
Pretty sure it's not going to "drop" straight out/downward.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2011 at 6:42pm
Not hardly a "drop-in"......you have to seperate the rearend from the torque housing at the battery box location and roll it backwards 3 to 5 feet and then pull the torque housing rearward about 12 inches.
Post Options Post Options   Thanks (0) Thanks(0)   Quote beaglejoe Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2011 at 7:39pm
Thanks...but you dont have to mess with the Tranny...right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2011 at 10:49pm
Sorry for the bad info. I was reading the manual and looking at the WC transmission picture.
Teddy (punchie) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teddy (punchie) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2011 at 5:31am
Beagle where are you from?  I'm in western PA  getting ready to scrap a housing. Need to hammer out a couple of gaskets and then it is going.  Teddy
Ac D-19, a Number of WD's, One WD45, Two 444 balers, Ac plows and etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2011 at 7:12am
Correct, no disassembly of the transmission assembly other than "spltting" it away from the torque housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote beaglejoe Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2011 at 9:29am
I live in Punxsutawney. Basically all I would need is the housing as the gears look fine. PM and I will possibly buy it off you. Thanks.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2011 at 8:45pm
before you get too involved,take the cover off over the hand clutch,and find out which one of the linkage pins are missing in the hand clutch.also how much damage to the pto intermediate gear...
