190xt pulls intermittently in high range?
allis converted View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis converted Quote  Post ReplyReply Direct Link To This Post Topic: 190xt pulls intermittently in high range?
    Posted: 10 Jun 2011 at 8:09pm
Hello to all I am new to Allis chalmers I have a 190xt when I am working it and try to shift into high range it pulls very slow but it does fine in low range, also when it has no load on it it works fine in high range. I have checked all the fluids could it be a week relief spring in the power director valve?
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2011 at 8:20pm
might check all linkages to make sure it is engaging all the way. I know that was a part of my problem on Dads 200.
Leon B Mo
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis converted Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2011 at 9:21pm
Thanks I will try it tomorrow and let you know if that was it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2011 at 7:18am
Dont run like this too much , you will warp the clutch plates in the POWERDIRECTOR !!! Need to get a 300 lb gauge on a 4 ft section of hyd hose and a FIX IT book to check the pressure going to the high and low side of the POWERDIRECTOR plates , if the pressures to low the plates wont engage fully , slip and break , the pressure is adjust able on the linkage , but also check the linkage attaching points as bushings and pieces wear over time throwing the pressures off ; even loose bolts on the foot deck of the tractor will cause the moving pressures ; oh yeah, you,ll love this tractor !!!
Edited by DougG - 11 Jun 2011 at 7:20am
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis converted Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2011 at 8:42am
I can't find any problems with the linkage I am getting ready to check the pressures. I cant' wait to see what it can do when it is pulling correctly now with only low range working right it has been pulling 6 16" white.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis converted Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2011 at 11:09am
Does anyone know where I can find the shims for the power director valve, from the pressure readings that seem to be the problem.
