180 Power Director UPDATE !!!
nsula_country View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsula_country Quote  Post ReplyReply Direct Link To This Post Topic: 180 Power Director UPDATE !!!
    Posted: 10 May 2011 at 10:30pm
I had posted questions a few months ago about troubleshooting a power director on a 180. I never found the test ports under the right hand floor board. I did take the relief valve apart several times in the PD valve body with no change.
Tonight I added a nut and some washers under the relief valve spring to raise the pressure for troubleshooting purposes only. As I was tightening the relief valve nut, I heard a "pop" in the valve body. I started the tractor and hydraulic oil started spewing. The line from the pump to the PTO valve spawned a split. I removed the line and brazed it up. I also removed the "shims" I placed in the relief valve.
After installing the line I decided to try the tractor out. I can now stall the tractor out in 4th gear with the brakes. If I have it throttled up and if 4th gear and engage the PD into high or low I can pull the front tires off the ground 12"-18". I'd say I "fixed it". Seems the relief valve spool was stuck.
Thanks!
CT
Edited by nsula_country - 11 May 2011 at 7:24am
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsula_country Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2011 at 8:47am
I am curious as to how much pressure is in the power director circuit now that the relief valve in the high/low valve is freed up. The AC shop manual says to test at the two 1/8" plugs at the PTO valve and gives recommended pressures at these ports.
Everyone I have talked to says there are test ports (1/8") at the block under the right hand floorboard by the parking brake pawl. Maybe this is on later S/N tractors or on 185's. I cannot find the plugs on my 1968, S/N 5000 180.
The reason I want to check the pressure is the parts book shows 1 shim under the spring. I have 4 shims under my spring (OEM shims). The service manual says that each shim is good for a 15 psi gain. Are 4 shims normal?
Thanks,
CT
