what ya think of my 8050
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Topic: what ya think of my 8050
    Posted: 05 Mar 2011 at 5:59am
Saved this one two years ago at the local auction. only payed 15,500 for it. had the oversized front tires on the front. 20.8x38's on it and 18.4x26. now its got 20.8r42 on step rims and goin to have 16.9r28's on the front in acouple weeks.
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 5:59am
o and yes i moved the front axle and weight bracket up also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 6:02am
i found a pic of what it looked like first.
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 6:14am
It looks a lot better with the front axle moved forward. I think these tractors were ahead of their time. Wasn't it several years before the other companies moved the seat ahead of the rear axle.JP
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 6:14am
VERY nice!! I'd say you got an excellent deal to boot. What prompted you to do the modifications, and were you satsified with the results?
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 6:56am
Nice looking machine!
Greg Kroeker
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 7:06am
Very nice. Owned an 8030 fwd for 16 years with very little downtime.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Toscani NE SD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toscani NE SD Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 7:14am
i dont like the look when the axle is moved,it just dont look right
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 7:44am
Toscani I totally agree with you.  They look wrong with the axle moved ahead, but i guess it has its reasoning, but just don't look right to me IMOP.
hillmonkey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hillmonkey Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 8:26am
LOVE the look of the forward axle. tell us what it took for that mod. were you able to unbolt,move forward, and redrill the hanger for the diff and then extend the drive shaft??
that is how they should have been from the factory. hm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 8:44am
i had to cut the rear hanger for the 2wd axle off. then just moved to rear most holes to where the front holes were, and then redrilled for the front bolts. i then had the driveshaft extended at a local machine shop. he also made the tube out of heavier material.
AdamA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AdamA Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 9:06am
Did the same axle mod too my 8030 and LOVE IT!!!! I think they look better also but looks take second place too performance any day.
57'D-17,78'185,83'6080,76'7040,84'8030 FWA.02'Dodge cummins
Byron WC in SW Wi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Byron WC in SW Wi Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 9:32am
How the turning radius compare?
I think both ways look great.  Still one of the best looking tractors ever made IMO.
Is it a powershift?
How many hours when you bought it?
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 9:46am
I want it! I love the 8000 series!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 4:31pm
yes powershift. and it had alittle over 5000 on it. the reason that i did it is because it should ride alittle better and also should go threw more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AdamA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2011 at 7:58pm
Turning radius on mine got alot better because I could set the steering stops in and still clear my loader,might cut it down a shade on a regular tractor but well worth it in my opinion!!! Night and day difference in ride!!
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2011 at 10:27pm
Better check the manual for tire size combinations.  Going up a size on the rear and down a size on front is a good way to break things if it is not a recommended combo in the manual.
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2011 at 10:37pm
Peterson I like the look. It makes the tractor look alot bigger when you move it up. The longer wheelbase rides so much better. The turning radius will be worse,but it was just to short coupled,wants to hop going down the road.
                                            IG
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2011 at 10:47pm
jordan, if you would have read the first post, i said it had oversized tires on the front. with 20.8r38's you should have 14.9r28 or 16.9r26. not the 18.4r26's. the correct combo for a 20.8r42 is a 18.4r26 or a 16.9r28.
MI8050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI8050 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2011 at 4:45am
Looks good!  I've got number 2285, mines an 83 and I really like it.  Best cab of the era in my opinion.  Looking forward to spring so I can get back in it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 5:41pm
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 8:49pm
What brand of tires are those? They look like they should really pull.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 9:11pm
BKT they are a nice looking tire. we will see what they pull like this summer.
leeyn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote leeyn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 12:43am
Nice looking machine! I love the 8000 seris...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 5:49pm
THANKS!!!!!
JCFarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCFarms Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2018 at 2:32pm
Still love it. Heheeee
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2018 at 7:30pm
So how is the tractor after a few years. How's the steering with the front moved up. Nice tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2018 at 7:56pm
Still going great! She has had a few upgrades in the engine though. My engine build thread is here someplace, along with the cam and flywheel swap thread too.
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2018 at 7:57pm
Burger King Tires, I've had em for about five years and can't tell them from any others. Aint nothing wrong with them yet.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2018 at 12:22pm
Hey, if it rides smoother in the field and down the road, I see no reason to not move the axle forward. I'm all for reasonable performance enhancing.
