Please help
robleighc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robleighc Quote  Post ReplyReply Direct Link To This Post Topic: Please help
    Posted: 16 Feb 2011 at 7:32am
We have an Alice Chamber Tractor that has gone nuts AGAIN.  it acts like it is running out of fuel.  My husband takes the return line off of the injector pump that goes to the fuel tank.  After he puts air pressure in the check value the tractor will run again for a minute or two.  Please let me know if you have any ideas what we can do to fix or make it run.
Thanks in Advance.  Scott and Robin
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 7:39am
Check for clogged screen in sediment bulb,if it has one.
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 9:06am
Sounds like a case of the flex ring in the pump is deteriorating and plugging the return fitting with the glass ball in it.  An injection pump rebuild is in the near future if this is the case.  I had this happen on my 180 diesel tractor, and I now have sent the pump off to have it rebuilt.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 9:21am
Ive heard that you can loosen the screws on the timing window to let fuel leak out relieving pressure in pump.If that makes it keep running,you definately have a governor ring going to pieces and time for rebuild.
Post Options Post Options   Thanks (0) Thanks(0)   Quote robleighc Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 9:36am
How much is it going to cost you to have this rebuilt?
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 9:40am
It depends on the pump, the tractor model, and the rebuilder. Here is an example, we just rebuilt the pump on our D21, it had a couple of worn parts, so price is s little higher, but it ran over $700.00  Not cheap to rebuild a pump.
Still in use:
Tim-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim-tn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 9:49am
If it runs after you blow air back thru the check valve the governor ring is going bad, for a temporary fix you can remove the return fitting from the top of the pump and break out the glass bead and remove the spring behind it. That should let it run , not the proper fix but will get you by awhile.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 9:54am
But when the governor ring is all gone so is governor control and the engine may overspeed, and in that process make throw a rod or two through the side of the block. That tends to be terminal.
Gerald J.
sandylakeimplement View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandylakeimplement Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 12:05pm
I agree with the prognosis of a contaminated check valve. The governor band deteriorates over time & comes apart in tiny rubber pieces which lodge in the check valve spring. When housing pressure builds to match the transfer pump pressure (8 or 10 psi) no fuel moves. The guys are right about a temporary fix but if the source is not fixed the pins of the 2 piee governor hub will hammer in their slots & metal will start to come off. AVERAGE repair in our shop runs about $525 and covers all the expected wear items but unexpected items (such as a cam ring or governor assembly) can raise that amount substantially. You can likely find a local shop to do this or you could send it to us.  Bill
Sandy Lake Implement
Sandy Lake, PA
724-376-2489
www.sandylakeimp.com
FIND US ON FACEBOOK
This page was generated in 0.043 seconds.
