Big 4 Tire Changer |
Post Reply |
orangereborn
Orange Level Joined: 12 Sep 2009 Location: NW WI Points: 1422 |
Posted: 03 Feb 2011 at 9:41pm |
I have a Big 4 Tire Changer that needs a new friction pad on the bead breaker post. Anyone help with info as where to get parts for this brand? Thanks...Dale
SIMPLICITY
Silver Level Joined: 19 Sep 2009 Location: ERATH LOUISIANA Points: 489 |
HEY DALE
DID U GET YOUR PACKAGE FROM LOUISIANA? |
dodgemam01
Bronze Level Joined: 26 Feb 2020 Location: ny Points: 3 |
I have the same problem. I have a big 4 older machine center post wont turn. leaks air when I press pedal and if I hold my finger on it will turn alittle.
HD6GTOM
Orange Level Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
Guys those machines were obsolete when I started in the tire business in 1986. Dodgemam, You can rebuild the check valves and make them work. You might have to get inventive to rebuild them. I think a customer of mine bought an inner tube and cut out circles of rubber and glued them to some heavy cloth to rework the valves. His turned after he did this. I do not know what became of the machine. He passed on over 20 years ago. Good luck with them.
Edited by HD6GTOM - 26 Feb 2020 at 10:27pm |
orangereborn
Mine is probably older than yours....I am the center post....I see that posting is from 9 years ago...I can't even guess how many tires it has changed....The valve got bad and I put a lever type water valve with a bleeder on it...Just keeps on going... Somebody wanted to change some alloy wheels, so they bought some No-Mar bars for it.
Post Reply | |
