Allis chalmers wd
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Topic: Allis chalmers wd
    Posted: 28 Jan 2011 at 10:13am
I ma get a chance to buy one and i would like to see more pics, oppions, and what to look fore good or bad. Also it dose NOT have a curved shifter but a streight on and to my understanding that is a wd not a wd45.
Thanks in advance
David Gibson (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Gibson (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 11:22am
You can't just go by the shifter. The late model WD's had curved ones. Check the right side of the engine for a side plate.
Edited by David Gibson (OH) - 28 Jan 2011 at 11:26am
David Gibson
http://www.darkecountysteam.com
1956 WD45
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 12:04pm
but wd45 didnt have streight shifters and this one dose so i asume this is a wd and the decals are right
MNfarmerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNfarmerAC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 12:17pm
The shifter is one way to go or check the engine side plate as mentioned before.  If it has a plate bolted to the side it's a WD engine.  Someone could have still put a "45" kit in it though.  Another thing you can do it check the SN.   It's stamped on the back of the transmission housing by the brake cover.
Brandon
1974 185
1977 185
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 1:51pm
Well hear is the story My neibor bought it at an auction arount the corner and he got it running and it runs good paints good he also bought some other equiptment and one was a 3 bottom 14 in plow and that was what it pulled. But we have alot of sand around hear.He went in for open heart a couple weeks ago sergery and there was some extra comlications and he was in for sugery for 7 hours and by that time his organs were shutting down du to slow blood flow. He was dooing good that saturday and sunday he was getting worse and on monday he passed away. So now i may have a chance to buy his wd and another tractor he had. Thats all i know about the tractor.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 2:27pm
It is a WD, two things to look at are wheel rim rot around valve stems and condition of tires. both items are spendy. The next thing id check would be oil pressure, hand clutch should have good overcenter snapin. Another thot is you will be dealing with a widow--- dont take advantage of her!!!!
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 3:14pm
I know what he payed for the tractor and i would spend that. He payed around 800$ for the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 3:19pm
Yeah, the whole widow thing is rough. My uncle had a C or a CA and I always thought it was cool. Then he passed away and we got to go over and look at it but what she wanted and what was practical was two different things. So as far as I know it is still sitting over there in the barn.
This page was generated in 0.219 seconds.
