Help 6070 engine issues
1abfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1abfarmer Quote  Post ReplyReply Direct Link To This Post Topic: Help 6070 engine issues
    Posted: 28 Jan 2011 at 12:02am
I just tore down my engine tonight, (water in oil) and found a pin-hole in #4 liner. But I was also blessed with the top half of the thrust bearing (crank wear edge) in the bottom of the oil pan. It looks like the crank is wore and dished out on the rear side of the thrust bearing (clutch end). So, the bearing are standard, crank hasn't been ground. What can I do, should I do? Do they make an oversized thrust bearings for end-play etc? This engine has the external thrust reducer on the front. What's next. Anyone have an engine or parts for this engine?
Thanks,
Shawn
Jim in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim in MO Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 2:50am
 call me 660 527 3512 or 660 460 0419  I can help Jim..
This page was generated in 0.118 seconds.
