my wd
fordf350dually View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordf350dually Quote  Post ReplyReply Direct Link To This Post Topic: my wd
    Posted: 23 Jan 2011 at 7:11pm
hello im new here. ive looked on here before as a guest but join up today. anyway i have a wd and i wanna make a nice puller out out with. wat can i do to get the most power with out changing the block such as head intake carb govener. wat are the specific parts. thanks in advance
jb from md View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 7:25pm
i see you are from Md what part?? welcome....JB
Edited by jb from md - 23 Jan 2011 at 7:26pm
8050 FWA, 190XT, 185, Styled wc, Unstyled wc, (2)C, (2)WD45NF, WD45WF, WD,416h, 716h, 312h, 8070 pedal.
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 7:32pm
I have heard you can put a 45 crank and pistons in it-no one can tell from the outside! The 45 carb is bigger and the manifold is different, so you might not get by with that if it has to be  'stock' .
Greg Kroeker
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordf350dually Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 7:36pm
i can put a ih combine carb and they would never notice here. and carrol county. but i have heard things about putting a 175 intake on it and a d17 head and carb. but idk how well it would work. and also hear about a 175 gov spring
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 7:44pm
welcome
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordf350dually Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 8:33pm
i also want the extra power for pulling wagons. run 28 big bales up the road with it
 every load.
David Gibson (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Gibson (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 8:55pm
Welcome to the forum.
David Gibson
http://www.darkecountysteam.com
1956 WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordf350dually Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 9:07pm
thanks for the welcomes
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 9:15pm
have it overhauled with a D17 kit for a WD45, you'll need converted to 12volt to start it though. also 170 gov spring.
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordf350dually Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 9:30pm
i might mention im 17 and on a 17 year olds budget. its not alot lol.  wat can i do with say 500
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 9:31pm
Welcome aboard. If we can get Mitch Pankey and some others to join in, they can offer a lot of good info on WD pullers. I'm not much help here, just wanted to welcome you to the forum and bump you back to the top.
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordf350dually Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 9:40pm
thank you. any info about wds would be great. just got it running again after main seals and a clutch
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 1:00pm
You can do abouts as much as your back pocket will let you.   A little over 5 inch stroke bigger bore 175 cam 175 gov spring  differnt valves port work for the head  Always raise the compression on a pulling engine into the 12.1 to 15.1 range. Torque gets real good at those compression ratios ? Gas is high but I havent found a thing that I enjoy that doesnt take some amount of money to do.  If you had the farmall c rod with the 1.750 rod journal stroked your wd 45 crank a 1/2 inch to 5 inches and had the 8.1 compression ratio pistons that i believe going by memory here had a compression height of 2.6 inches you would be at a compression ratio of 15.1 . Of coarse if you had a piston of less than 2.6 inches in comp.height then you would have less comp. ratio.
Edited by mlpankey - 24 Jan 2011 at 1:20pm
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 2:47pm
If you want some cheap power up the rpms with a D-17 or 175 govenor spring. You can also change the carb. For pulling I would find a larger set of tires and rims you can put on during pulling season. Remember whatever you do will make it burn more gas if your using it in the field. Our D-17 burns a third more gas in a day than the WD-45 and they both will do the same amount of work. If you are going to continue to work the tractor you probably wouldnt want to make any drastic changes which would affect the everyday usefulness of the tractor. Around here the antique pullers are all so modified that they are only useful for pulling. I wish there was a stock pull closer to home.
Terry GA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terry GA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 6:12pm
I put a 170 govenor spring and larger carb on mine a few years ago,and it made a big difference .
I couldn't repair your brakes, so I made your horn louder.
Anthony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anthony Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 8:35pm
Welcome to the forum Ford Dually, and by the way I love the name......own three Fords myself
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordf350dually Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2011 at 3:05pm
i only work it once a year pulling hay. they pay gas so the power is worth it. and ya i love my turck. 85 cab n chassis diesel. turned it up and done a whole bunch 2 it. but wa carb should i use also the intake. im think a 175 intake and mabe port and polish . tire wise i dont have the money. only think i got is 14.9 28s off my massy 65 that will fit. they are a bit bigger overall then my 12 28s but will it make much diff? i think the gov spring would be a good idea tho. do i just take the little plate off the govenor assy. or do i need 2 take my time cover off. beause i refuse 2 do that right now. since i just goe it 2gether.
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2011 at 3:10pm
All you take off is the plate on the front of the gov. housing. It takes a little finegeling to get the spring off and on. Be sure you got a good set of needle nose pliars.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordf350dually Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2011 at 8:00pm
o sounds like an easy deal then. any idea on the rest
This page was generated in 0.176 seconds.
