m & w sleeve part number
alan-nj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Topic: m & w sleeve part number
    Posted: 02 Jan 2011 at 2:41pm
does anyone know the part number of the m&w sleeve that goes with the m&w ap48 piston?  i need to order a new set of rings.  i was looking at the hasting's site and they list rings by the sleeve part number, not the piston part number.  i won't have the sleeve part number available until i take the engine apart, and i'd like to have the new rings ready when i take it apart.  thanks  alan
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 2:48pm
I ordered a set from Hastings about a month agoe for some M&W AP48 and AP48 pistons.
It's listed as part 2c7794  for the M&W pistons, gives the quantity and dimension of the rings included in the set.
Hang on to your wallet, the cost was about $140 for a set of rings.
I do not know what O rings to use on the sleves.  It's fairley skinney and flat.  The Mahle/ Clevelite sleves use a different O ring which is common and easy to order.
Sometimes these sleves are wore to bad to be usefull, bore gauge them, I've seen nice looking M&W sleves that were .018 taper and out of round.
Edited by wi50 - 02 Jan 2011 at 2:53pm
Bruce Nelson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bruce Nelson Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 2:58pm
The sleeve set is #SP-48. The M&W ring set is # RS-501
