coolant drain on a B
Ed in TX View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed in TX Quote  Post ReplyReply Direct Link To This Post Topic: coolant drain on a B
    Posted: 12 Dec 2010 at 4:41pm
I have 2 B tractors I bought this year. I'm pretty sure they both have straight water in them. I still have a lot of work to do to them so I don't want to put antifreeze in them just to have to drain it back out but we're expecting a cold winter. Where do I drain the coolant to make sure the block is empty?
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 4:44pm
Drain at the bottom hose and behind the carb
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 5:25pm
Like he said.  you can see the copper pipe sticking out of the drain valve located behind the carb.  Most I have seen have been broken off.  also valve on bottom of pipe attached to radiator.
Bob, North Carolina
1949 B
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 6:49pm
pull lower hose pipe all the way off and open block petcock.   I would probably get nervous and pour some antifreeze thru it also.  It aint that expensive
This page was generated in 0.048 seconds.
