Will a Terra Tiger fit in the bed of a pickup?
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Topic: Will a Terra Tiger fit in the bed of a pickup?
    Posted: 02 Dec 2010 at 6:10pm
Im planning on looking at a Terra Tiger this weekend and an curious if it will fit in the bed of a F-250 with an 8 foot bed and a tool box.  Thanks for the help!  Anything to look for on these machines?
 Thanks,
 Joe
Life is simpler when you plow around the stump.
JM in KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM in KY Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2010 at 7:44pm
Yes, a Terra Tiger will definitely fit in the bed of a pickup.  It will actually fit in a full size pickup with a short bed.  You should have no problem with an 8 foot bed.  The Terra Tiger is wider than the space between your fender wells.  You will need to take the two middle tires off to make it fit.  Doing that will allow the front tires to be in front of the fender wells and the rear tires to be behind the fender wells.  Hope this helps.
jrjuday View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jrjuday Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 12:47am
If it's yours, and some low-life wants it, you can bet they'll make it fit!
