b PTO
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Topic: b PTO
    Posted: 27 Nov 2010 at 7:52am
 I removed the pto from my b to replace it wit another one, the po welded a pully to the shaft. I think the gasket is supposed to have a lip at the bottom to create an oil reserve for the hydraulic pump is what im geussing. Someone tore away that lip for some reason. anyway are new gaskets available for the pto ? or do I have to make one. if I make one, I dont know how high the lip should be. Does anyone have one to measure it for me ?
John
'41 Allis B
'45 Allis B
'49 Farmall Cub
'72 IH Cub
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 9:49pm
Yes, the gasket has a lip at the bottom to dam up the oil so if you are going down a hill the oil doesn't run to the front of the transmission and leave the hydraulisc starve.
They are available from Agco and on this site. Bob
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2010 at 8:15pm
The pic has the PTO cover gasket in this B/C gasket/seal set. (the large gasket middle left) As the pic shows, it does have a lip, or dam. Hopefully you can approximate the lip placement from the holes.
Edited by GBACBFan - 28 Nov 2010 at 8:33pm
are genuine." - Mark Twain
Brad MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad MI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2010 at 8:39pm
I've always made them. If ya lay the 1 1/2" side of a framing square centered on the second two mounting bolt holes from the bottom and draw a line across the gasket you will have the correct height for the oil dam.
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2010 at 9:03pm
Thanks
'41 Allis B
'45 Allis B
'49 Farmall Cub
'72 IH Cub
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 7:42am
Scaleing the above post,  the top of the dam is 3 tenths of the overall height of the gasket from the bottom
   I have taken off lots of B/C/CA ptos and never found a dam gasket. Err, I mean a gasket with a dam.  Must all have been flat land tractors
outlook6 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote outlook6 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 8:36am
I don't want to hijack this thread but, is the gasket and seal set shown above commercially available as a kit (especially the gaskets)?  Or do you have to order the gaskets individually?  In either case, where's the best place to buy them?
Thanks in advance,
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 5:02pm
Others probably know the answer to this, Jim. I believe I stole... er... borrowed... I mean benchmarked this pic from Ebay, but I'm not positive. I grabbed it from somewhere for future reference because my memory'a short. If this hasen't been kitted to sell, it should be.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad MI Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 6:53pm
I agree Ken, I've also removed lots of B/C PTO units and found no dam. The only dam I ever remember finding was destroyed and laying in the bottom of the casing. In restoring them I don't worry about the dam either.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 8:16pm
I think if the tractor was built without the pump the gasket would be different because they list one for the PTO housing without a pump but it is nolonger available.
AGCO sells the one for with a pump for around $8.00 and change.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 8:20pm
I think Jeff may have the answer here. My 1940 has the hydraulic pump, and has the dam gasket. That certainly makes sense.
