Brush Hog
JCSinPITTS,PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCSinPITTS,PA Quote  Post ReplyReply Direct Link To This Post Topic: Brush Hog
    Posted: Yesterday at 10:58am
i have a 5 foot drag behind "brush hog" and i would like to get a bigger like 6 footer to pull behind WD-45.  the 5 footer i need to overlap since the tractor is like 6 foot wide.  However I cant seem to find a used 6 foot drag behind in my area.  How much trouble is it to buy a 3-point hitch adapter and the get a 6 foot 3-point mower? does the hydraulic lift need to run all the time or what holds the front of the mower up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 hours 50 minutes ago at 11:06am
Did you ever consider setting your drawbar in the "long" position and then swinging it fully to one side or the other ?? That would surely gain you six inches and you'd just have to mow in lands.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 3 minutes ago at 12:53pm
Keep looking for a pull type you won't be happy with a 3pt behind the WD45.They are out there in fact I have 2 AC 6ft pull type cutters.WD45 could handle a 7 or 8 ft depending on what you are cutting.
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 32 minutes ago at 2:24pm
I have an Allis 5 ft snap coupler that I run on my 45 diesel most of the time. It makes the front end very light on it.
I have ran it on my straight WD but the front needs weight.
Have a neighbor who runs a 9 or 10 foot pull type brush mower on a WD but he never lets his grass/ weeds get too big.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 16 minutes ago at 6:40pm
A Wood's C80 is a good fit for a WD, WD45. Pull type, 80 inch cut, single action hyd lift and built right. I mowed some with one around waterways, property lines and sheds but didn't use it enough, so I sold it. It gave my WD all it wanted when you hit some 6' Johnson grass. Bad part, getting hit in the back by rocks, debris. Don't look back without safety glasses. Good luck.
Leon B Mo
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 19 minutes ago at 7:37pm
That is a bad part, plus the dust in the fall…
I did some fall mowing last year and when I got home I looked like a straw man!!
ja ecmn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ja ecmn Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 48 minutes ago at 9:08pm
I have a 5 foot 3 pt Woods brush hog on a WD45 that works well. I use hydraulic cylinder restrictors set at a level cutting height, that way the hydraulics are always down while cutting and not constantly pumping pressure to the cylinders. But yes I do have to overlap but at times the 45 is giving all its got in heavier brush.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 36 minutes ago at 9:20pm
The hydraulic pump does NOT have to "pump" to carry the front of the mower. It has to "hold". Depth collars would be one way to do that, but not needed if the hyd pumps hold valve is in good working order.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 41 minutes ago at 4:15am
The Woods C-80 is a pretty good mower.  Here are some things to look for, if you run across one:  Flip it over and check the center frame welds, If cracked or broken, spindles flex, causing belts to wear or jump off. Blades are a unique set up, little bolt to hold a crescent moon shaped pivot pin retainer from popping up and out.  make sure it's all there. Chain shield up front is nice.
The D-80 is the same mower, just newer. C/D 80's are not true bush hogs, somewhere between a BH and a finish mower.  THink the highway median mowers from the 80's...Wink
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 58 minutes ago at 5:58am
How about limiter chains on the 3PH to maintain the height of the front of Bush Hog.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 5 minutes ago at 6:51am
Dad bought an FMC Sidewinder (SW72) to go behind his WD back in ‘59 and now I am using it behind my D15. I like it a lot better than the 3 point on my Hindu Ford. Heading to the farm this week to give it some exercise.
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 2 minutes ago at 6:54am
I also have a 3pt. Woods on a WD45 and use the collars to preserve the hydraulic pump even if it only operates the while lifting.  It doesn't cut the full tire track but that really doesn't show because the tires mash it down.  Have to go into low gear occasionally when in 7 ft. Johnson grass.  Almost bought a 6 ft. AC but it went for more $ than I wanted to spend & needed a little work.  No weights on the tractor & it's not front end light.
