Will a genuine Allis coming off 170 fit a 180
Darwin W. Kurtz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darwin W. Kurtz Quote  Post ReplyReply Direct Link To This Post Topic: Will a genuine Allis coming off 170 fit a 180
    Posted: 10 hours 26 minutes ago at 11:06pm
or will I have to do modifications to the ldr in order to make it fit - Any thoughts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 10 minutes ago at 11:22pm
If it is an A-C 500 loader it shouldn't be a problem. Always remember a 180-185-190-200 were wider at the side frames over a D-17/170/175. A 500 loader on the narrow framed tractors had spacer plates between the side frames and the loader frames. Also the wide frame tractors were probably 5 inches longer, so that has to be dealt with too, with multiple holes for the axle brackets. An A-C 400 loader has no frame spacers and is too narrow and short to fit the larger/wider/longer frame tractors.
Edited by DrAllis - 3 hours 8 minutes ago at 6:24am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darwin W. Kurtz Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 51 minutes ago at 7:41am
How do I know for sure what ldr I have here? I was hoping it is a #500 like I thought I got - Is there a model plate somewhere?   It is genuine orange and the frame has Allis Chalmers in big letters
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 49 minutes ago at 7:43am
If there are 5/8" thick spacers between the loader frames and the tractor side frames, it has to be a "500" series, which can be made to fit. If there are no spacers whatsoever, it must be a "400" and it is too narrow. If it is a "500" loader and it was mounted on a D-17/170/175 there has to be spacers.
Edited by DrAllis - 1 hour 47 minutes ago at 7:45am
