190xt3 ether start
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Topic: 190xt3 ether start
    Posted: 13 Oct 2026 at 9:31pm
Have a really original tractor that has the mechanical quick start ether injection kit on it. Someone has it plumbed wrong in my opinion. All the lines are broken off but looks like ether line went into turbo inlet pipe and the filter minder was connected to the intake manifold at the intake heater area.
My questions are was that kit factory installed, dealer installed, or aftermarket?  Would it have used an atomizer or just an elbow to spray ether?
The filter minder should be in the turbo inlet pipe…correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2026 at 1:39pm
Minder should be between filter and turbo. Ether should be in intake manifold. I would think it has the tiny holes for fine spray. On my 8000's the atomizer is in manifold and marked for position at installation to spray fwd and backward.
