7020 clutch pedal |
Kurt WI
Joined: 19 Oct 2011 Location: Cascade WI Points: 3248 |
Topic: 7020 clutch pedalPosted: 4 hours 48 minutes ago at 8:41pm |
My 7020 clutch pedal yesterday went to the floor and no return. Worked great on Saturday baling the last of our hay, backed it in the shed shut it off. After church we went out to clean up the baler and put it away for the year. Got into start her up, pushed the pedal and pushed easy and fast. Did start as the safety switch must be activated, but didn’t move, put my foot under the pedal and lifted it up. Got it to move as long as I pulled up the pedal. So my question is what happened and how can I fix it! Thanks Kurt
WD D17D 170 190xt 190xtIII 200 7020
DrAllis
Posted: 3 hours 26 minutes ago at 10:03pm |
Quick fix if you need the tractor is a tarp strap wrapped around the clutch pedal and up to the steering column. The real fix is to replace the broken clutch pedal spring inside the instrument panel. This is a Power Shift tractor, right ???
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2554 |
Posted: 3 hours 21 minutes ago at 10:08pm |
It has to be a power shift. And yes, broken return spring on the pedal.
