7060 dash warning light axces |
whatscooking
Topic: 7060 dash warning light axcesPosted: 8 hours 50 minutes ago at 3:59pm |
How do you go about getting to the warning light cluster? I have one that doesn't light up.
68 D21 81 7060
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2553 |
Posted: 6 hours 12 minutes ago at 6:37pm |
Take both engine side hoods off. The small panel, behind the center hood,comes off next. It has a spring hook on each side holding it on. There's an even smaller orange panel that's held with two 3/8ths bolts that needs to come off. It is actually in the cab and directly over the center of the dash. The bolts are accessible on the outside of the cab and are right in front of the windshield. That panel has to be moved forward and taken out front ward. If there's insulation, remove it. Unplug the wiring harness from the circuit board and then remove the 4 screws holding the circuit board to the plastic dash panel. That takes a 1/4 inch nut driver.
