ISO 190XT 3PT Sensing rod |
MadCow
Joined: 27 Aug 2023 Location: South Dakota Points: 240 |
Topic: ISO 190XT 3PT Sensing rodPosted: 15 hours 20 minutes ago at 8:12pm |
I'm looking for part 0234574-1.
It's the 'sensing rod' that connects the bell crank to the 3pt lower arm on the right side of the tractor.
DrAllis
Posted: 14 hours 57 minutes ago at 8:35pm |
With your draft arms let down to "level", grab a hold of them and see if they can move forward/backwards by pushing/pulling on them by hand. There should be basically zero movement. If there is, the torsion bar hex ends, left mounting bracket and bushings are worn out. That link rod is what sends the draft signal to the "Traction Booster" system to transfer weight when plowing with a mounted plow. The TB system is useless if things are worn out.
MadCow
Posted: 1 hour 20 minutes ago at 10:12am |
I take it this is too much movement.
I suppose these are all scrap yard parts? https://youtu.be/WrPoSMqK4JQ?is=XnE4hpWRIuvrMxos |
MadCow
Posted: 1 hour 9 minutes ago at 10:23am |
I do have a 3pt conversion for a snap coupler and I think it is tight I'll check that.
