7060 cab floor |
whatscooking
Topic: 7060 cab floorPosted: 3 hours 15 minutes ago at 7:18am |
Have had the cab floor out going after leaks. When I pulled the mat there was a piece of angle laying by the console unhooked under the mat. Bolt holes line up, only one in console has threads and one on floor. Saw a Pic of a ragged out 7060 that had that angle on top of the mat with one bolt into console and one into the floor, looks only as a matt holder,is that correct?
Also obviously that console side cover has got to come off to get to the cable ends. How scary of a project is it to open that up? Edited by whatscooking - 3 hours 14 minutes ago at 7:19am |
68 D21 81 7060
DrAllis
Posted: 3 hours 9 minutes ago at 7:24am |
Angle iron at the front corner ?? bolts to the floor to stabilize the console assembly. That was added when they went to the "T"-shifter for the Power Director and even tho it may be a Power Shift, still had that brace. It isn't for the floor mat.
whatscooking
Posted: 3 hours 8 minutes ago at 7:25am |
Top or under the mat?
68 D21 81 7060
DrAllis
Posted: 2 hours 41 minutes ago at 7:52am |
UNDER ...directly to the cab floor for a brace/support.
