7060 tie rods |
whatscooking
Topic: 7060 tie rodsPosted: 23 Sep 2026 at 6:03pm |
Where or where not to buy?
68 D21 81 7060
Mikez
Posted: 24 Sep 2026 at 5:44am |
They are still available from agco
whatscooking
Posted: 24 Sep 2026 at 10:43am |
At better than twice the price, is there a reason for that?
68 D21 81 7060
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9226 |
Posted: 24 Sep 2026 at 11:55am |
Sometimes you get what you pay for....Sometimes not. How's the quality on the cheap ones? Will it take 2 sets over time to get hours?
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42484 |
Posted: 26 Sep 2026 at 2:39pm |
If you have a part number try search engine for tie rod ends - or see if a match is there
I just went through this for my AC 715B TLB and ended up with a fork lift company that use to sell AC machines - NO they were not cheap but units fit and were greaseable where stock were not - should outlast me and rest of machine as believe ones were replaced were original to machine |
Coke-in-MN
Posted: 26 Sep 2026 at 2:45pm |
Google search comes up with several matches and several prices . https://www.worthingtonagparts.com/allis-chalmers-tie-rod-outer-new-wn-70269353?srsltid=AU7gw4VSVYEo0KiLIxRhhbn6SKV2TX1Kdkq74O0yGvHuXelm02rZTwgR |
rw
Joined: 28 Oct 2009 Location: United States Points: 390 |
Posted: 26 Sep 2026 at 9:14pm |
I was sold a will fit and the right end is different from the original factory end. The original has a slot in the socket that the ball stem comes through. The slot fits tight and keeps the tie rod indexed to the steering cylinder. The aftermarket set up lets the tie rod twist when you turn and the steering cylinder eyes rub on the mounting brackets. Works ok, they said it was all you could get for parts, its been on there several years, still works ok, but i wish it was like the one that came on the tractor.
