D 15 tire
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: D 15 tire
    Posted: 23 Sep 2026 at 12:20pm
When I checked the psi in one of my front tires today water keeps coming out. Other tire is fine. I have the valve up and shot a little air in before checking. Hear water bubbling when I add air. Had 15 psi in it. Could this be a bad valve or a leaky tube? Thanks
Edited by ACinSC - 23 Sep 2026 at 2:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2026 at 2:59pm
Jacked the front tire up and filled it up to 40 psi. Also tightened the Schrader valve a bit. No more water spraying out of the valve. Bled the psi to 25#. Still good. Guess I got lucky. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2026 at 3:23pm
Its a common thing to ballast front tires for additional weight. If the tire migrated south from colder climes, check the "water" to see if it tastes salty.  If so, I'd drain it and check the rim for rust. JMHO...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2026 at 4:02pm
Thanks Dave but I had these tires put on new a couple years ago. Just had plain water put in. Don't know what was going on.
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2026 at 5:56pm
From your second post it sounds like you tightened a loose Schrader valve and solved the issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2026 at 3:45am
Yeah Jim, guess that was it. Thanks
