Pressure Testing Old Tractor Cooling Systems
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Topic: Pressure Testing Old Tractor Cooling Systems
    Posted: 11 hours 41 minutes ago at 9:30am
What's everyone's favorite way/tool to pressure test radiators and such on our old AC tractors? I almost picked up a radiator pressure testing kit from Harbor Freight the other day but it didn't look like any of the cap adaptors would work.
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 37 minutes ago at 9:34am
I used one from AutoZone on my D 15. Had to put up a deposit but got it back when I returned the tester. Good luck
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 36 minutes ago at 9:35am
An air compressor and a leather or rubber glove. Just be careful not to over pressure it.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 38 minutes ago at 10:33am
I "borrowed" a test kit from O'Reilly. Paid the deposit, (full retail price) and never returned it. Of all the test caps in the kit, the only one I've been able to use is the rubber expansion cap. I've used it so many times over the years I don't miss the "deposit".
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 43 minutes ago at 2:28pm
In the past I have made up a hose fitting with a T in it , then using a regulator to control air pressure just charge system ( on trucks and cars ) using present cap on radiator .
 On tractor one would need to tap into block drain with a T and gauge and valve .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 46 minutes ago at 3:25pm
Have my own, bought close to Forty years ago, have to take apart and lube the piston ring occasionally but make pressure just fine and gauge is as accurate as I need.  Used on Allis 7G as well the 180 and numerous OLD Cap Style cars or trucks.  Not bought a update cap style for the screw on caps.
Edited by DMiller - 5 hours 46 minutes ago at 3:25pm
