6080 starting |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4443 |
Topic: 6080 startingPosted: 17 Sep 2026 at 7:46am |
So back in the middle of July I did some maintenance on the old girl, including new batteries and cables. I mention this because the engine now spins so much faster it’s not funny. Also starts much faster/better. I think the cables were the big thing, corrosion was pretty bad. The other night it got down in the mid 50’s, curious, lets see if it will start? Spun a little bit but lit pretty quick. Before, it would have never started without being plugged in.
Moral of this story; Faster cranking speed=good! If you have a hard starter, look into the cables. They might just be the problem. Just remembered, need to get an oil filter so I can finish the maintenance up on this one.
DougG
Posted: 17 Sep 2026 at 3:06pm |
Yup- so true, had a newer Harbor Freight winch - 2 years old that slowed down bad- cut the battery cables cover was green and bad - put new ones on - worked perfect- a week ago my 5020 done the same - new positive cable and good to go!
Ricky38
Posted: 20 Sep 2026 at 12:00pm |
Crusty cables cause so many fake fuel problems. Glad it's spinning faster. Get that filter!
