HD6 Clutch Throwout Bearing Grease... Thing
Stevie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stevie Quote  Post ReplyReply Direct Link To This Post Topic: HD6 Clutch Throwout Bearing Grease... Thing
    Posted: 16 Sep 2026 at 5:42am
Anyone experience replacing the grease line that runs from the throwout bearing to the steering clutch housing cover on an HD6?
If you did, how did you do it? I've visited three places in the largest town within an hour of me and they all three did the hmm/giggle/chuckle for a few minutes before telling me they can't help. Both my lines are completely rotten, both ends either broken off or hanging by a sliver of metal.
Parts information below:
045507 Hose, lubricating, throwout bearing
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2026 at 9:34am
The first type was a line  with a wick  and recieved the oil from bevel gear case and the second type is a  greace gun line instaled on the bigger inspection stering cluch cover
Post Options Post Options   Thanks (1) Thanks(1)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2026 at 3:12pm
A grease gun hose works as the threads are the same size or can be fit with a reducing fitting , 1/8 pipe thread , drilling a hole in cover of housing to bring hose or fitting to access point .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stevie Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2026 at 5:27am
A local tractor shop speculated the pipe thread might be grease gun line; I hadn't gotten to trying to figure out how to test that theory.
I've ordered some parts, we'll see how it goes.
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2026 at 2:16pm
Everyone here who has dry backend HD6 ran a greaseline hose to the throwout bearing to ensure lubrication
tits tyres and tracks
they all cost you money
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2026 at 10:16pm
Grease gun hose works , if you have the felt wick to ring gear case be sure to put plug in that hole . otherwise you will have oil in clutch housing if left open
