8000 series cab door re-install
pdh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pdh Quote  Post ReplyReply Direct Link To This Post Topic: 8000 series cab door re-install
    Posted: 13 Sep 2026 at 8:59am
Bottom hinge on one of the doors on my 8030 broke so had to pull the door off to fix.  Got it off but it was a struggle so looking for tips/techniques for the re-install before I tackle it.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2026 at 9:08am
If you would explain what caused the struggle i might can help. Ive taken them off by myself several times
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2026 at 9:27am
ii worked on a large CASE last month..Backed the pickup truck up to the cab/ rear wheel so i could stand in the bed and lift the door up... for more stability.
pdh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pdh Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2026 at 11:44am
When taking it off it didn't seem to have enough clearance on the bottom unless i tipped it toward the front of the tractor and then rotated the front bottom counterclockwise - but then the top corner hit the roof.   If it matters this is the passenger side door.  Will the top pin go into the top hinge hole with the door "flat"against the cab?
Edited by pdh - 13 Sep 2026 at 11:46am
pdh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pdh Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2026 at 11:49am
Also - does the bottom hinge rotate on a bushing of some kind - or just a flat washer?
Edited by pdh - 13 Sep 2026 at 11:49am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2026 at 1:05pm
Unless its different than my 84 8070 i shut the door take the bolts out of the bottom hinge open the door and slide it off the top hinge
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2026 at 1:07pm
Of course you have to unhook the cylinder that holds the door open
1984 80780
1957 D14
616 tractor
SilverShoes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2026 at 5:42pm
My 8070 is broke, haven’t gotten to the point of taking it off yet, wondered how to take it off myself. Mine is crocked on the door frame
