Wood boat repair
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: Wood boat repair
    Posted: 08 Sep 2026 at 8:19am
Have a old cypress? boat with two holes in the bottom. Anyone have any experience with a repair ? Guess I should use cypress if that's what it is? Maybe I can just slap some flex seal stuff on it? Yeah right
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2026 at 9:12am
depending on the size of the hole and location.. If it dont show, fill with fiberglass...
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2026 at 9:51am
Probably had this boat 30 years, but I think someone had put a skin of fiberglass on it that did no good. Pretty sure it has 2 holes in it big enough to put your fist through? Haven't looked at it in years. Need to put it in my shop and check it out. Thanks
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2026 at 10:29am
Thanks
WinkWink  Come on you need to do it right.ConfusedConfusedConfused.....what are you thinking.....................you need to staple some window screen on them then the flex seal.LOLLOLLOL
I have never had a boat, but have got lots of years use out of leaky water troughs. Keeping water in not so different than keeping water out. Also no prize for looking good. A patch of what ever you think. In my case steel washers a good coat the Henery Tar roof patch. then another washer on the other side. Suck up with a bolt. So in your case wood, Wink with lots of flex seal (? or what ever) and wood on top some screws.Confused But as I say very crud, you know the farmer get er DONE.
Cry I know not very helpful. But hopefully it gets you thinking, of possibilities.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2026 at 2:53pm
Thanks Ray, I'll put my thinking cap on.
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2026 at 10:06pm
   Hey AC,,,,repairing fiber glass is really  not very hard to do,,,unless you got holes bigger than a good sized ice chest like you use for keeping your beer cold,,,,!!  Even then,,,you just got to buy bigger pieces of fiberglass cloth and more mix,,,,,Give it a try,,,!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2026 at 3:41am
Thanks Joe!
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2026 at 5:05am
Thanks Joe!
 Seriously AC,,,my only issue with doing fiberglass repairs has been that I am kinda allergic to the fiberglass itself,,,,I use  a heavy long sleeve shirt with gloves and a respirator and pick a low wind day to do the work. Give it a whirl,,,Clap
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2026 at 5:25am
I know a guy that had an old family wood boat (I don't know what kind of wood) that had a hole in it. He took a hole saw and drilled it out. He made a round wood plug that fit tightly in the hole. I believe he used some sort of epoxy after he had the plug in.
If I remember correctly, he used the same kind of wood (maybe mahogany?) that the boat was made from.
Edited by WF owner - 09 Sep 2026 at 5:25am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2026 at 6:13am
WF has the right idea !
I'll add....
take out a bit more than the 'hole', so you have goo wood.
Taper both the hole and the 'bung' for a good but slighlty loose fit
Be 100% sure the hull is DRY
Mix the 50/50 ratio epoxy  really really well
Allow to cure for two days
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2026 at 6:57am
Thanks guys!!
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2026 at 8:22pm
There is or was a forum member "johnkc" who had a boat/boat repair business.  He hasn't been on here since May of 26 and I have no idea what happened.  Not helpful at this point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2026 at 1:22am
Thanks Dennis! I'll take all the help I can get
Post Options Post Options   Thanks (1) Thanks(1)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2026 at 4:40am
When using epoxy, remember there are different formulas for different applications.  For deep cracks, there is 1, for shallow, there is another. go to totalboat epoxy for explanations...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2026 at 5:13am
Thanks Dave, I've been looking at total boat online.
