706 forklift
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Topic: 706 forklift
    Posted: 03 Sep 2026 at 9:42am
I have a 706 forklift with a bad perkins engine. Its one with precombustion chambers that have caps outside the head. The rest of the forklift works great. It even has good brakes. Id like to replace the engine with a more modern direct injection engine. Im wondering if a 433 AC out of a 6000 series tractor would work. If anyone has any experience with something like this id like to pick your brain
Thanks
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2026 at 10:41am
I have a 706B that someone took out the ford gas engine and replaced it with a Cummins 4bt, it needed new engine mounts made but it bolts to the bell housing, and because the 433 had a standard bolt pattern, its doable, I would find one from a gleaner, if I would have done the conversion I would have put the Allis Chalmers in, the Cummins is a great engine, but I like the sound of the 433 in our backhoe, better
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2026 at 10:56am
Mine has hydraulic pump drive on the front left side. I may be wrong but i dont think the combine endines have it
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2026 at 11:10am
that's true, the pump bolted into the Cummins, but the hose work is kinda jenky but it wotks
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2026 at 12:28pm
Thanks. I hadnt thought about a 4bt. Gives me more options
1984 80780
1957 D14
616 tractor
ac-mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac-mike Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2026 at 8:42am
I have a 706B that the Ford gas engine was changed to a Ford Diesel engine.
D-12III, 200D, 170G, HD-3, D19D 3pt, D17D High Crop, WD45G p/s, D15IID, D15IIG, D15G IND, 655, (3)WD45D p/s, 700, 816
