Allis Loader #500
Darwin W. Kurtz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darwin W. Kurtz Quote  Post ReplyReply Direct Link To This Post Topic: Allis Loader #500
    Posted: 30 Aug 2026 at 7:07am
There is a 500 Ldr for sale on Facebook Marketplace - What does it fit?
Looking to find out what loader will fit a 170 0r 190 Tractor? Does anyone have one or have mounting brackets?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2026 at 7:16am
500 series loaders fit the D-17 and D-19 to begin with. They also should fit 170-175-180-185-190-200 tractors.  As I remember, anything smaller than a 180 requires spacer blocks between the tractor side frames and the loader frames because the smaller tractors are a bit narrower. Axle brackets vary between inboard final drive tractors versus outboard final drives. Brackets are pretty easily fabricated. Some 500 loaders had front hydraulic pumps with loader control valves and some did not need those options. So, know what you're buying and don't assume anything.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darwin W. Kurtz Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2026 at 8:40am
Thanks for your help
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2026 at 6:58pm
Anchor End at Final Housings on a 190 or larger is Different Configuration as well.
