Autolite 405
Josh(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Topic: Autolite 405
    Posted: 27 Aug 2026 at 6:02pm
What are you all using as replacements for autolite 405s? Now that they are nla.
Allis Express
'65 190XT, 37 B, '72 170, '83 8030, and the IH 560 was a mistake
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2026 at 6:59pm
Autolite A405 - Alternative spark plugs
There is 1 replacement spark plug for Autolite A405. The cross references are for general reference only, please check specifications for your application.
Autolite A405 replacement spark plugs
Indirect matches
There are 154 replacements for Autolite A405. These are indirect matches for Autolite A405.
When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network and Amazon Associates.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2026 at 7:13pm
Specifications for Champion N5C
Thread diameter
14mm
Thread reach
19mm
Hex size
21mm
Seat type
flat
Tip
non projected
Construction
Standard construction
Terminal
Removable
Gap
0.7 mm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2026 at 8:34pm
what engine are you putting the 405 in ??
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2026 at 9:35pm
Thread diameter
14mm
Thread reach
19mm
Hex size
21mm
Seat type
flat
Tip
non projected
Construction
Terminal
Removable
Gap
0.7 mm
Is that not an old style plug that was built to Imperial measurements?  So 3/4" reach and 13/16" hex. What thread was it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2026 at 8:56am
To answer my own question the thread size is metric - 14 x 1.25. I did not know that even tho I've installed hundreds of them. But I think the hex was not metric????
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2026 at 10:57am
190xt is what I am trying to tune up, but I think that was the plug allis used in all gas engines from d17 and newer.
Allis Express
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2026 at 2:44pm
My Norton motorcycles use the N 5  Champion as well as other Mfg in that range , but over time I just use the N 5 -
 A while back a local discounter liquidator had some plugs - Champion lawn and garden - Looked up heat range and other specs = was a N5  - bought 30 plugs at 25 cents each
 Now running them in my Moto-Guzzy as well
Somehow the idea a spark plug is now a $6 to $9 cost item - ????
