6080 Alternator Pulley
977.3Ford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 977.3Ford Quote  Post ReplyReply Direct Link To This Post Topic: 6080 Alternator Pulley
    Posted: 23 Aug 2026 at 2:22pm
Is there a replacement for the alternator pulley out there somewhere? The pulley on my 6080 is wore out to the point where its eating belts and is an issue. Agco and Hy Capacity don't have one available, and ive tried a couple aftermarket that are the wrong bore size or too thick overall. I don't have a good machine shop locally so trying to avoid that route if I can.
The pulley that I have is 3.5" O.D., .670" I.D., and is a double v for 1/2" belt.
Jimmy
1982 8050 Powershift
1982 6080
1992 R52 Gleaner
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2026 at 2:54pm
www.brillman.com has a double pulley for 1/2" belts that is 3-3/16 for a 17MM Shaft. part # B9028-015
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2026 at 8:03pm
I'd try searching these 2 numbers online: 778-1062 and AGCO 70262155.
#778-1062 pulley is replacement for; AGCO #70262155. a 2 groove, 1/2" belts, 3 1/2" OD, .670" bore, the catalog didn't list pulley outset dimension.
  Fits 6060, 6070, 6080, 7010, 7020, 8010.
 Sadly, company that had these closed a year ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2026 at 8:23pm
https://www.hy-capacity.com/electrical/components/pid6322/alternator-pulley/
when you click on the link it puts a  "/%20" on the end of the link... backspace and delete those 3 symbols.
Edited by steve(ill) - 23 Aug 2026 at 8:26pm
JoeOnt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeOnt Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2026 at 5:23pm
Doing some quick searching, the closest thing I can find A&I A-AFD5012. Shows a little small, but depending on how they achieve it being rated for a 10 & 13mm belt, the 13 (1/2")  belt may ride out some, which would help the practical diameter some.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2026 at 8:22am
We are also having belt issues.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2026 at 5:41pm
The parts house that I get most of me electrical stuff lists a pulley for 6060,6070,6080,7010,7020,and 8010. Replacing #70262155. 3 1/2" outer diameter,.670 bore,1/2 inch belts. They have good stuff and cheap.
