Allis B block
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Topic: Allis B block
    Posted: 16 Aug 2026 at 3:37pm
The engine for my B is a BE block. I am going to rebuild it soon. Can I use the 3.375 liners for the CE engine in it instead of the 3.250 liners?
'41 Allis B
'49 Farmall Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2026 at 4:11pm
almost all aftermarket kits are a slight OVERBORD of the new liners and pistons... These will all go into the original CE and BE engine blocks..
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2026 at 4:45pm
Thanks.
'41 Allis B
'49 Farmall Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2026 at 5:04pm
i did a Google search of posts on the internet, and this is the SUMMARY... I have never heard of an "early B block" that had a different sleeve bore than the later ones.. FWIW..
AI Overview
Yes, the aftermarket 3.437" (3-7/16") overbore liner and piston kits will fit the older Allis-Chalmers BE engines found in early B tractors. The BE (116 cu. in., 3.250" stock bore) and the later CE/125 cu. in. blocks share the same external architecture and wet-sleeve outer dimensions, allowing you to drop the larger sleeves and matching pistons right in.
Important Installation Notes
  • Check the Lower Block Seal Land: Some very early production blocks have a different inner diameter at the bottom seal land where the o-rings seat. Most major aftermarket overhaul suppliers recommend verifying that your lower block seal land measures 3.718" I.D. before installing the 3.437" liner kits. --- i dont know where they got that info... i have never heard that...
Edited by steve(ill) - 16 Aug 2026 at 5:06pm
